Some recent work on the 404C, last weekend and just today:
Clearcoat on the Carrosserie Peugeot plate.
For reassembly, I used the original insulation as a template to cut Dynamat Xtreme panels, mounted the Dynamat and then glued the original insulation to it.
Heater core with the ancestor of modern "set and forget" heat level - thermostatically controlled water valve.
Heater core box is mounted in the car with new foam to seal between the air intake in the bodyshell and the bakelite box.
Wiper mechanism mounted - both spindle assemblies are brand new.
