Schlumberger M80 sensor
Berichtdoor Jamie » 14 feb 2016, 12:45
Hallo ik ben nieuw op dit forum ben.
Ik ben gevestigd in de UK en hebben een B31 Cabriolet met een mislukte nokkenas sensor.
Weet iemand hier hoe te repareren van een of waar ik kon krijgen een vervanging?
Dank u
Jamie
Hello I am am new to this forum.
I am based in UK and have a B31 Cabriolet with a failed camshaft sensor.
Does anyone here know how to repair one or where I could get a replacement?
Thank you
Jamie
Jamie
Geregistreerd: 29 sep 2015, 06:06
Re: Schlumberger M80 sensor
Berichtdoor Frank.04 » 14 feb 2016, 15:04
Hello Jamie,
Are you sure it's the sensor?
Is it broken/damaged or just failing?
The sensor is hard to get, but in many cases it's not the sensor itself but the ECU fitted underneath the dashboard.
The electronics inside are due to aging and ask for a stronger sensor signal.
Therefore it's reasonable to suspect the sensor, wherever its is in fact the ECU failing!
Please supply more info!
Frank.04
Berichtdoor Jamie » 14 feb 2016, 20:50
Hello Frank,
Thank you for your quick reply.
I bought the car recently.
The sensor is definitely not working. Unfortunately it has been dismantled by the previous owner.
I am told that the ECU is OK, but have no way of proving it.
I will need a replacement sensor to test it.
Jamie
Jamie
Berichtdoor E-504-C » 20 feb 2016, 20:28
Hi Jamie,
I do have a spare sensor for the Schlumberger electrical unit of this car.
I know it works, so if you're interested in it, send me a PB.
Kind regards,
Eduard
504 C33
E-504-C
Geregistreerd: 17 mei 2004, 19:28
Woonplaats: Rotterdam
Berichtdoor Jamie » 24 feb 2016, 11:04
Hello Eduard,
I have sent you a private message.
Thanks
Jamie
Jamie
Keer terug naar 504
Gebruikers op dit forum: Geen geregistreerde gebruikers. en 46 gasten
