I there,
The speedo on my 'new' samba cabriolet didn't work so I went to see if it was disconnected.
There wasn't a cable there!!!!
I can (I hope) get a new cable but cannot see where on the transmission it connects. The Haynes manual shows a picture of the speedo cable but I cannot see the connector from under the bonnet. Please could somebody tell me exactly where it connects so I can fit the new one.
Also, I took the air filter cover off the carbs as it was idling too high (about 1500 rpm) but was suprised that both the carbs said Weber on them, not Solex! Are they the same company or have I got non-standard carbs on the car?
Lastly, the fuel guage doesn't work. Are there any checks I can make to see if it the sender, the guage or the wiring between them?
Many thanks.
Mike
