Zoals de titel aangeeft wil ik een group buy opzetten voor een LSD deze groupbuy gaat via het andere peugeot forum peugeottuningclub.nl
Voor het bestellen van deze differentieel is een minimale afname van 5 stuks nodig. Hierbij zoek ik mensen die geïnteresseerd zijn in de ML differentieel.
De LSD differentieel is voor de handgeschakelde ML versnellingsbak welke op verschillende auto's zit.
De auto's waar deze versnellingsbakken onder zitten zijn:
Peugeot 406 V6 type D8 en D9, Peugeot 407 V6, Peugeot 607 V6, Peugeot 807 V6, Sommige Peugeot boxers
Citroen C5 V6 type 1-2-3, Citroen C6 V6, Citroen C8 V6 en sommige Citroen jumpers
Het betreft in dit geval een differentieel van mfactory.
Gain a prominent advantage over the competition with the MFactory Helical Limited Slip Differential. Through the smooth and constant distribution of power to the wheels, the MFactory Helical LSD puts the power-to-the-ground and maximises your vehicle's traction. A must for any race car, be it Street, Strip or Track!
Diamond Cut to exacting tolerances from Forged High-Nickel-Chromium-Molybdenum Steel
Perfect fitment & finish ensures hassle-free installation & maintenance, each and every time
Designed using leading-edge Solidworks 3D CAD & Cosmos FEA software
Advanced Gear Geometry minimizes parasitic drivetrain losses. Race transmissions built with MFactory components transfer, on average, 1-2% more power to the ground over our competitors!
Stress Tested on loaded dynos
Ensures our differentials are strong enough to handle the shock loads encountered during racing, yet also durable enough to handle the variable loads encountered during day-to-day driving.
Multiple Stages Available (Honda & Mazda)
Users can choose (and upgrade) between the various Stages available, which determine the Bias Ratios. With the MFactory Helical LSD, upto 75% torque can be transferred to the one wheel! A must-have for serious road-racers.
2nd Generation Design
The MFactory v2 Helical LSD is lighter, stronger and more efficient than any other Helical LSD on the market today!
Covered by the MFactory Feel The Torque™ 30-Day Money Back Guarantee! Click here for more details
An Industry First! If you do not feel the difference after installing your new Limited Slip Differential, you may return the product to us for a full refund (excluding shipping costs) within 30 days of the purchase date
Covered by the MFactory Lifetime, Globally Transferable Warranty
Whether used on the Street, Strip or Track, all MFactory Helical LSD's come with a Lifetime, No-Hassle, Globally Transferable Warranty
No-Load/One-Wheel Syndrome
A common misconception is that a Torsen-Style Differential is useless under a no-load situation (e.g One wheel in the air). This myth has been further perpetuated by our competitors of whom have limited understanding of how a Torsen-Style LSD functions. This no-load situation does not apply to 90% of users. For the other 10%, there is a simple solution to the problem that our competitors will not tell you; simply tap your brake pedal.
Ze hebben deze LSD niet op voorraad en zal ik zelfs een standaard differentieel moeten versturen zodat ze hem na kunnen maken. Voor een ma bak hebben ze wel een diff op voorraad en geven ze hierbij aan dat ze tot 1000pk kunnen handelen....
Bij een minimale afname vragen ze hier €650,- voor en is dit incl. verzendkosten.
Mochten er vragen zijn dan hoor ik het graag.
