604 Toit ouvrant
604 Toit ouvrant
Berichtdoor 604Prague » 21 feb 2020, 16:47
Hello,
I am new on the forum. I have recently bought Peugeot 604 SL (1978). It is in very good condition with only 87 000 km.
This car has sliding roof (toit ouvrant) which works perfectly. However, when fully closed, the gap between the roof and the sliding roof plate in front is only 4 mm wide contrary to rear gap which is 15 mm wide thus not tight enaugh. Therefore sliding roof needs adjustment.
Could someone advise me how to do it.
Bellow is a Google translation to Dutch (thus may be full of mistakes).
Thanks
Vaclav
(Prague)
Ik ben nieuw op het forum. Ik heb onlangs Peugeot 604 SL (1978) gekocht. Het is in zeer goede staat met slechts 87.000 km.
Deze auto heeft een schuifdak (toit ouvrant) die perfect werkt. Echter, wanneer volledig gesloten, is de opening tussen het dak en de schuifdakplaat vooraan slechts 4 mm breed in tegenstelling tot de achterste opening die 15 mm breed is, dus niet strak genoeg. Daarom moet het schuifdak worden aangepast.
Kan iemand mij adviseren hoe het te doen.
Bedankt
Vaclav
(Praag)
604Prague
Geregistreerd: 21 feb 2020, 16:05
Re: 604 Toit ouvrant
Berichtdoor risky » 21 feb 2020, 22:34
Hi Vaclaf, welcome
I have never worked on an open roof of a Peugeot 604.
ask your question on this topic again here have more chance of reaction there are plenty of people on this forum who know it viewforum.php?f=45
Greetings,
Opel Ascona B 1.9S 1977
Peugeot 604 ti automaat 1978
risky
Forumbeheer
Woonplaats: westfriesland
Berichtdoor 604Prague » 24 feb 2020, 16:35
Thanks! I put the question again on the particular section of the forum.
Regards
Vaclav
604Prague
Berichtdoor Walle69 » 24 feb 2020, 22:55
Hello,
the roof panel slides into four black plastic stops that sit on the left and right side. These plastic stops will make sure that the panel slides upwards the last centimeters so that the roof panel is flush with your roof. You will see them once you have opened the roof.
I guess that they are mounted too far to the front and should be adjusted some cm towards the rear...or they are broken...
in the below link you will discover what I mean
https://retropeugeot34.com/p/bac-complet-de-toit-ouvrant-electrique-peugeot-604-avec-moteur
Laatst bijgewerkt door Walle69 op 25 feb 2020, 19:18, in totaal 2 keer bewerkt.
2664 en 2849 klinkt goed
604 GTI automatique 1985
504 V6TI 1978
Walle69
Woonplaats: Solna
Berichtdoor 604Prague » 25 feb 2020, 18:34
Hello,
Thanks for your suggestions and link to the deatiled pictures - they are great!
The mentioned stops are fixed to the sliding roof frame, each by two bolts, and cannot be adjusted. However, I have compared the pictures from your link with original Catalogue - page 84 (http://public.servicebox.peugeot.com/cl ... 1582647434) and it seems that the adjustment can be done by the centralizing screw (item No. 8427.12 - centrage vis) located somewhere at the emergency close lever. The question is, if that screw is accessible from inside the car...
604Prague
Berichtdoor Walle69 » 25 feb 2020, 19:08
Hello,
The stops should determine how far the panel will be able to slide....
if the panel slides further I guess (on of) the following would be the case;
1. The stops are wrongly mounted or broken
2. The pins/axes that slide into the stops are wrongly mounted/bend
3. If they are good en well mounted: the exterior plate is mounted wrongly to the interior plate
Do you know if the exterior plate has been off ?
I took it off in order to repair it and respray it. And it was not that easy to bolt it back onto the inner plate I remember.
The back and front stop should sit 305 mm from each other.
504 V6TI 1978
Walle69
Woonplaats: Solna
Keer terug naar 604
